Need some help top end problems
Just got this banshee runs great until you run wot. Pulls really hard through all gears until high rpm in 6th it seems like the right cylinder quits then it hits for a bit and pulls hard then quits again. Almost like a rev limiter lol it sounds like the right cylinder quits firing to me or stops getting gas I'm not sure. Any ideas where I should start.
A little info tors delete pro circuit pipe jetted boost bottle starts on first kick runs great until 6th top end
Sent from my SAMSUNG-SM-N900A using Tapatalk
Ok it's not the spark plugs put two new plugs in today and tested it out again for sure the right cylinder is not firing at high rpm. intermittently fires occasionally. but what do you think this is cdi box or coil or no fuel
Detonation
(Classic scenario) guy buys bike, figures last guy tuned it right, new guy rides bike in short bursts and everything seams fine.....till he finds a nice wide open stretch and burns it down.
What does floats are great mean?
Hard riding with lots of heat in motor?
Or a WOT run down the street?
Edited by WINDYCITYJOHN400
Any riding hrs of riding or just a quick race down the road. I road for 3 hrs the other night it would run great as long as I dint go wot. Changed the plugs today just to try it. payvement road by my house 1st through 4th pulling hard 5th started to die off at wot then shift to 6th pull hard for a sec then sounds like right side just stops firing.
Never seen this before is why I ask on here.
I didn't post to get a bunch of crap from people thinking some stupid kid that don't know nothing. My only option as of now is to just start pulling parts off a good bike and trying one by one. Where should I start coil, cdi anything else that could be failing anyone ever seen anything like this
Nobody gave you crap.
I looked at your join date. Your not a noob.
But you have been here long enough to know that if you had the carbs apart to clean them and check your float settings....you could have at least checked to see the jet/needle/airscrew settings
AND POST THAT INFO.
If it's ignition you should know the routine....
Plug caps, wires, stator, flywheel magnets, CDI..
Wait!....Is this a Trinity motor?
I havnt opened it up yet to check stator or flywheel magnets. It runs way to good for me to beleive thats a posibuility none of the easy stuff has worked now I'm onto replace and test just don't want to chase and chase and chase and could have found someone that had a similar problem and possible fix
ohms test the plug boots.  if your running a resistor plug  put in non resistor. also unscrew boots and see if the ends are rusted at the connections.  if they are  replace both boots, cut back just a tad of wire reinstall.  gap plugs to 20 tho. make sure stator pickup is around 20 tho gap also.
if thats ok.  remove petcock and clean the in tank filters.  check petcock, float level, and vent tubes on carbs are not plugged and not straight cut and hanging below the bike.  remove mains and dump tubes completely, make sure all the holes in the dumps are clean and the air holes in the fronts of the carb inlets are clean and clear.   if this is all ok. try upping the main jet one size.  if it gets worse.  try one size smaller.  2 strokes dont like to run out for a mile or so at WFO  you will need some special setups to run for a long period of time at wide fuckin open
