Porting cub
Timshee
I would like some opinions, it's a clean up ported cub with stock unported cases. Do you think I will pick up any et from porting cylinders and cases? So far the fastest it's been is a 4.02. Who would you recommend I got it narrowed down to Titan, precision or k&t
If its a 421 Cub  I would maximize the potential of the unported motor and setup before porting. Make sure the domes are set up correctly. If its strictly a ridgid drag bike I would work on the chassis setup, tires, clutch and gearing. If its a stock chassis, buy a ridgid, or make the stocker as light as you can get it. If you've done all of that or believe you've already made it as fast as you can, then go with PPS for the porting.
  • Like 1
