bansheerider313 Posted May 25, 2014 Report Share Posted May 25, 2014 Bought another banshee, this one needs completely rebuilt. Going with 795s and 4mil crank.has 65mm bore.im wondering if I can run a 39mm pwk thats bored to 41mm as a single setup.It has just the stockers , should I jet them for it or run single or just buy new carbs? If new what would you buy? Thanks in advance Quote Link to comment Share on other sites More sharing options...
bluebanshee98 Posted May 25, 2014 Report Share Posted May 25, 2014 FFS... Keep the stock carbs on it. Quote Link to comment Share on other sites More sharing options...
special06shee Posted May 25, 2014 Report Share Posted May 25, 2014 If its gonna be a play bike run the stock carbs. If your gonna do a drag set up, buy another pwk39 to match the other.. Single carb setups are for sissy girls. Quote Link to comment Share on other sites More sharing options...
bansheerider313 Posted May 26, 2014 Author Report Share Posted May 26, 2014 its just going to be a dune bike.i dont really want to keep the stock carbs, i was hoping I could run a 2 into 1 but after reading a little about them ive changed my mind.so what would a good set be? 34mm pwks? Or 36's? Quote Link to comment Share on other sites More sharing options...
bansheerider313 Posted May 26, 2014 Author Report Share Posted May 26, 2014 well id really like the single setup, one lest thing to deal with and jet, less hastle and less clutter.question is would a 39 bored to a 41mm be enough for a 4mm? Quote Link to comment Share on other sites More sharing options...
special06shee Posted May 26, 2014 Report Share Posted May 26, 2014 You WILL regret running a 2-1. Dont be lazy. It takes 5-10 mins to jet per carb. Bike will run better with the duals. Why do you not like stock carbs? They are actually a decent carb and will/do work very well on MANY application including a 4m dune setup. Quote Link to comment Share on other sites More sharing options...
bansheerider313 Posted May 26, 2014 Author Report Share Posted May 26, 2014 because im more fond of the pwks and tm flat slides...also ill need the throttle valve for one and rebuild them both and a idle kit too.id rather just buy some bigger carbs that I don't have to fuck with..ill be running either cpi sm inframes or rdz sb oof's Quote Link to comment Share on other sites More sharing options...
trickedcarbine Posted May 26, 2014 Report Share Posted May 26, 2014 (edited) Then try a set of 28-33 PWK's. If you port it, 35's will suffice. Edited May 26, 2014 by trickedcarbine Quote Link to comment Share on other sites More sharing options...
bansheerider313 Posted May 26, 2014 Author Report Share Posted May 26, 2014 Ill be having f.a.s.t. port it and ok sweet.ill order a set of 35's then.thanks Quote Link to comment Share on other sites More sharing options...
