What would you do to get the compression down?
I have a stock stroke and 66mm pro lite pistons with stock ported heads. Noss head w/ 22cc domes. I recently changed out the cylinders and pistons. The cylinders were decked .004 because of a nick in the head. I'm using a .015 base gasket and my squish is at .045 with that. I was told between .040 & .050 is optimal. I did a cc fluid check and I get 15cc's in the chamber with 22cc domes. By method of a online calculator(http://www.cbperformance.com/v/enginecalc.html)
I get a cranking compression of 160psi. That puts me at 14.5:1 compression. Way to high for pump gas. 23cc domes would lower my cranking and my uccr compression. The thicker the base gasket I use will increase my squish. Then I'm out of the optimal range. If I run the .031 base it will drop compression to 12.5:1 but increase my squish to.061. Last year I didn't know my uccr but my cranking compression was 150psi with 21cc domes, stock base gasket (.026) and undecked heads. The bike ran great last year and even ran a tank of 87 octane in it with no problems. The pistons didn't show any signs of detention either.
Don't have time to cut domes for it. Big trip of the year is 7 days.
This is the price of earning late in the game.
Run a thicker base gasket for now. The squish will open up....but that's better than too tight or too much compression.
Maximizing power for a long trail ride doesn't seem to be a big priority. Not to mention the need to get jetting established for this new motor........
