TwistedMethods Posted May 21, 2014 Author Report Share Posted May 21, 2014 So nothing has to go there then ? And I did what was suggested with the pressure plate still not fully engaging when I try to roll it in first Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
Starwriter Posted May 21, 2014 Report Share Posted May 21, 2014 Explain YOUR definition of engage and disengage. Let's see if it matches everyone else's definition. Quote Link to comment Share on other sites More sharing options...
TwistedMethods Posted May 21, 2014 Author Report Share Posted May 21, 2014 We'll I put it in first gear an try rolling it back an forth with clutch lever in and it's not letting me push it's still grabing first gear I made sure pressure plate arrows matched I have adjusted actuator arm when I pull the lever pressure plate move but just seems like not fully Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
Starwriter Posted May 21, 2014 Report Share Posted May 21, 2014 So, not DISengaging is what you're talking about? These things aren't like a car. You can't just disengage the clutch and push them around. Quote Link to comment Share on other sites More sharing options...
TwistedMethods Posted May 21, 2014 Author Report Share Posted May 21, 2014 We'll if your bikes not running and in gear you can pull the clutch in and push it correct ? Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
Starwriter Posted May 21, 2014 Report Share Posted May 21, 2014 No. Quote Link to comment Share on other sites More sharing options...
TwistedMethods Posted May 21, 2014 Author Report Share Posted May 21, 2014 seriously ? I could with my dirtbikes Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
03DMshee Posted May 21, 2014 Report Share Posted May 21, 2014 seriously ? I could with my dirtbikes Sent from my iPhone using Tapatalk Then buy a dirtbike again.. clutches are sticking...it will be fine. Quote Link to comment Share on other sites More sharing options...
possum Posted May 21, 2014 Report Share Posted May 21, 2014 ffs Quote Link to comment Share on other sites More sharing options...
TwistedMethods Posted May 21, 2014 Author Report Share Posted May 21, 2014 Will do Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
