04 bashhee
"trail" ported
head shaved .020"
fmf fatty pipes with turbine core 2 silencers
K&N filter with lid removed
stock carbs
elevation 1000'
70F average temp
All trail riding
where is a good starting point for the jetting?
Edited by 350smokey
what reeds?
if stock or boysen reeds then stock pilot and 330 main
if vf4's then 27.5 pilot and 330 main
Update, I went with 340 mains, stock needle in 3rd (middle) clip, 30 pilots 1.5 out on the air screw. Its got good bottom end (for a banshee) and its insane top end. my problem is from about 3500-4500rpm it is so flat it has a hard time getting through it in the higher gears.. Plugs after a tank look fairly dry and a light brown colour but the weather is colder then normal so as it warms it will richen up a bit. How do I go about getting rid of the midrange face plant?
