blast off Posted May 9, 2014 Report Share Posted May 9, 2014 Hello Gents, So I bought a Cascade throttle extender and when I put it all back together and tighten the throttle cover the throttle is tight. The thread for the throttle is hitting the cover. Has anyone ever had this issue? I was thinking to grind down the inside of the cover a tad to give it some clearance. I have the washers and hardware installed correctly, it even comes with instructions. ANy thoughts or Ideas would be appreciated. Cheers! Quote Link to comment Share on other sites More sharing options...
Strm Trpr Posted May 9, 2014 Report Share Posted May 9, 2014 Same thing happened when I installed mine on my 02. I can't remember what I had to dremel out. Post a pic of the underside of the cover and inside of the throttle it may spark a synapse or two. I suffer from CRS... Quote Link to comment Share on other sites More sharing options...
blast off Posted May 9, 2014 Author Report Share Posted May 9, 2014 Ok, well im glad Im not the only person that its happened to lol. I do not have a pic at the moment but I will snap a couple when I get home and have them posted up. Thanks for the quick reply Quote Link to comment Share on other sites More sharing options...
Strm Trpr Posted May 9, 2014 Report Share Posted May 9, 2014 If you look at it closely you'll see what's up when you lower the lid on. If I'm not mistaken, there's the threaded part sticking up and a nut on that. When you button up the lid, a rib in the lid touches the screw. Dremel that part out of the lid and you're all good. Quote Link to comment Share on other sites More sharing options...
blast off Posted May 9, 2014 Author Report Share Posted May 9, 2014 alright cool. I will do that and also post up a pic in case someone else runs in to it. the throttle is really nice and because of the bearing and longer tab its waaaaay easier to press. No more sore thumb lol Quote Link to comment Share on other sites More sharing options...
pp13bnos Posted May 9, 2014 Report Share Posted May 9, 2014 Hmmm, I've installed one on my wifes bike, and one on mine...both didn't need any mods. Post pics when you can. Quote Link to comment Share on other sites More sharing options...
Strm Trpr Posted May 10, 2014 Report Share Posted May 10, 2014 I installed one on my buddies 89, no problem. My 02 required dremeling to the underside of the lid. Quote Link to comment Share on other sites More sharing options...
special06shee Posted May 10, 2014 Report Share Posted May 10, 2014 My 06 did the same thing. Grind some of the stud off and youll be good. Quote Link to comment Share on other sites More sharing options...
VoOK Posted May 12, 2014 Report Share Posted May 12, 2014 Posting this for blast off. Von meinem iPhone gesendet Quote Link to comment Share on other sites More sharing options...
blast off Posted May 12, 2014 Author Report Share Posted May 12, 2014 Thanks Bro. So, I grinded the bolt down like 2-3mm and I grinded the inside of the cover (to the left of my finger) about 2mm and the thing is STILL TIGHT! I dont know what is going on with It but Im going to have to call Cascade and ask if they have heard of this or if they have any ideas. Ill get a pic up of the inside of the cap now and the bolt but i grinded them down pretty fauckin far. Thoughts anyone? Quote Link to comment Share on other sites More sharing options...
Strm Trpr Posted May 12, 2014 Report Share Posted May 12, 2014 did you over tighten it? Quote Link to comment Share on other sites More sharing options...
blast off Posted May 12, 2014 Author Report Share Posted May 12, 2014 Over tighten the cap or the shaft screw? Either way, no. when the cover is a tiny bit loosened it does not touch/stick Quote Link to comment Share on other sites More sharing options...
Strm Trpr Posted May 12, 2014 Report Share Posted May 12, 2014 What's circled in red is what's hitting the end of the screw. Quote Link to comment Share on other sites More sharing options...
blast off Posted May 12, 2014 Author Report Share Posted May 12, 2014 Oh man, That might explain the wear marks on the washer lol. I had a feeling it might be that but I really diddnt see that hitting when I layed the cover down. Now i feel dumb lol. But hey thanks, I will grind that down when i get home and retest. Thanks for clarifying that. Quote Link to comment Share on other sites More sharing options...
Strm Trpr Posted May 12, 2014 Report Share Posted May 12, 2014 yeah man, you can see the wear marks on that little protrusion. Cut that back and down a touch and you should be good to go. Quote Link to comment Share on other sites More sharing options...
