BANSHEEBEEFM2M Posted May 7, 2014 Report Share Posted May 7, 2014 ok my crank seal went out so my motors with my builder having him fix all the little shit too basically replacing everything thats worn out or almost worn out lol doin it like you should, but what size base gasket do i get? ss lr crank blaster pistons 66mm bore, cool head with 17cc domes. and Im trying to buy new air filters but what size do i need for 33mm carbs? any links? also to the right outerwear sizes for them? going to outfmae pipes so I wanted to run bigger then average filters. Quote Link to comment Share on other sites More sharing options...
BANSHEEBEEFM2M Posted May 7, 2014 Author Report Share Posted May 7, 2014 looking for 8-10 inch air filters. Quote Link to comment Share on other sites More sharing options...
sheerider11 Posted May 7, 2014 Report Share Posted May 7, 2014 Your builder should have access to all that. Unless it's not a shop. In that case, get on the phone with a builder that you can ask and order the gasket from. I have k&n I got from cam. I have 35 pwk but he sold me the size for 39 because of there size and fit and my motor. Quote Link to comment Share on other sites More sharing options...
BANSHEEBEEFM2M Posted May 7, 2014 Author Report Share Posted May 7, 2014 He doesn't have a shop Sent from my SCH-R970C using Tapatalk Quote Link to comment Share on other sites More sharing options...
BANSHEEBEEFM2M Posted May 7, 2014 Author Report Share Posted May 7, 2014 Bump tryna get this shit ordered today Sent from my SCH-R970C using Tapatalk Quote Link to comment Share on other sites More sharing options...
Deadbeat Posted May 7, 2014 Report Share Posted May 7, 2014 just reorder wtf you had before...does your builder know what squish is? Quote Link to comment Share on other sites More sharing options...
BANSHEEBEEFM2M Posted May 7, 2014 Author Report Share Posted May 7, 2014 Ya. But how can I tell what thickness base gasket it is? First time this motor has been went through since I got it Sent from my SCH-R970C using Tapatalk Quote Link to comment Share on other sites More sharing options...
Deadbeat Posted May 7, 2014 Report Share Posted May 7, 2014 you or he could measure the thickness Quote Link to comment Share on other sites More sharing options...
BANSHEEBEEFM2M Posted May 7, 2014 Author Report Share Posted May 7, 2014 Ok Sent from my SCH-R970C using Tapatalk Quote Link to comment Share on other sites More sharing options...
BANSHEEBEEFM2M Posted May 7, 2014 Author Report Share Posted May 7, 2014 We're can I order wrist pin bearings and rings Sent from my SCH-R970C using Tapatalk Quote Link to comment Share on other sites More sharing options...
Deadbeat Posted May 7, 2014 Report Share Posted May 7, 2014 http://www.bansheehq.com/bansheehq-sponsors/ Quote Link to comment Share on other sites More sharing options...
trickedcarbine Posted May 8, 2014 Report Share Posted May 8, 2014 Jeff and Cody get shit done fast at FAST! They have just about anything you could want for about any combo you want. Tell them you want 8-10" filters and what carbs they are for. They will do the rest. As far as your base gasket, I usually have about 6-7 different gaskets and I like to just drop the jugs on with out the head to see which gasket puts the piston where it should be in relation to the ports. Then find the deck height and order the domes to go off of that. Since you have domes.(you're sure they are for this motor?) maybe you can bolt the cylinders on and the head. Squish test it, and calculate what the difference should be. Ultimately that's more like guessing as you need to be sure the gasket is putting the cylinders where they need to be for optimum set up not just to fudge a squish number. When calculating, remember different gasket materials squish down some. So if you mic a gasket at say .025, it may smush down to .020 1 Quote Link to comment Share on other sites More sharing options...
Nightmare Posted May 8, 2014 Report Share Posted May 8, 2014 Sandtoyz, he's closest to you. Sent from my HTC One_M8 using Tapatalk Quote Link to comment Share on other sites More sharing options...
