tors eleminator kit adjust
Hello, guys just wondering how do i adjust the new tapped air screw. I noticed that the one on my new banshee werent adjust the same way on the carburetors is it normal ?
There is one more screwed than the other just wondering
thank you
I might be a little confused with your question, but the newly tapped threads with screw would be your idle screws. Give your cable some slack at handle bars, then use those screws to set your idle on each carb. Once you get desired idle, adjust cable.
I mean that the tapped screw are not adjust the same way in the 2 carb
So i want to know if its important that the screw in the carb have to be adjust exactly the same? In the 2 carb or if it doesnt matter ?
