Shawnsmith Posted April 29, 2014 Report Posted April 29, 2014 Got a 4 mill 68mm drag port cooled head 19cc domes 39mm carbs k&n pods vf4 reeds lockup needing some roundabouts on some jetting elevation is around 3200 average temperature is 85 90 Quote
trickedcarbine Posted April 29, 2014 Report Posted April 29, 2014 Stock cylinder bike? And who ported it? Quote
locogato11283 Posted April 30, 2014 Report Posted April 30, 2014 Stock cylinder bike? And who ported it? Read the title.. I would start with 165 main, 48 pilot and air screw 2.5 turns out. Quote
RadarRacing Posted May 1, 2014 Report Posted May 1, 2014 At 1200 feet that setup would probably be close to 168 main give or take a few either way so locos 165 sounds about right at higher elevation. If you have much additional ignition timing jetting requirements will be more. It also depends on needles in the carbs. Quote
Shawnsmith Posted May 2, 2014 Author Report Posted May 2, 2014 Timming is at plus 6 not sure about what needles it has but there on the bottom clip setting Quote
RadarRacing Posted May 2, 2014 Report Posted May 2, 2014 I usually try to do the needle setting and mainjet settings hand in hand and try to get them both close at the same time. If it is sluggish off idle at all with the needles all the way rich you may need to lean them out and then get the mainjet close too. I would start pribably one or two higher than 165 but that should be close. I would start with the needle in the middle. When you have the mainjet about spot on then do the needle. If you are doing plug chops I like to do a 1/2-2/3rds throttle ride on some type of hilly or dune area and have my plug chop look a decent bit richer than the W.O.T. chop. I like a beer bottle or chocolate colored ring 1mm or more tall. That usually gives me a snappy hard off idle bike that launches hard. If you end up having the mainjet exactly perfect and start leaning or richening up the needle more than 2 clips then you may need to adjust the main again. Quote
