Steering Stem Removal
Matt7373
Hey just picked up a Beat up Banshee and stripping it down to nothing for a complete rebuild. Everything has come apart great so far. Until the steering stem. Seems like the nut at the bottom of the stem just keeps spinning freely without catching any of the threads. Cottor pin is removed, shaft is not spinning but the nut just wont come off. Just spins and spins. Am I missing something ? ????
Haha thanks for the welcome. This Banshee needs lots of work. Complete front end including A arms. All bearings and seals. Previous owner did no maintnance at all. Missing hardware everywhere. Just have the steering stem and engine left to pull off. Then it will be stripped down to the frame. Fun lil project to keep me busy.
Once you get the stem out, and you pry out the seals, you need a special tool to get the bearing out. Here is the one I made. You need a 3/4" bolt which will have a 1 1/8" hex head. You can also jam 2 nuts together and use a 1 1/8" socket to turn it or you can use a pipe wrench on the 3/4" bolt.
Here is the bolt kit that we all use.
http://www.ebay.com/itm/Yamaha-Banshee-Polished-Stainless-Steel-ATV-Bolt-Kit-/300352177883?pt=Motors_ATV_Parts_Accessories&hash=item45ee6286db&vxp=mtr
[q uote name=Starwriter" post="1604978" timestamp="1398739773]Once you get the stem out, and you pry out the seals, you need a special tool to get the bearing out. Here is the one I made. You need a 3/4" bolt which will have a 1 1/8" hex head. You can also jam 2 nuts together and use a 1 1/8" socket to turn it or you can use a pipe wrench on the 3/4" bolt.
http://www.ebay.com/itm/Yamaha-Banshee-Polished-Stainless-Steel-ATV-Bolt-Kit-/300352177883?pt=Motors_ATV_Parts_Accessories&hash=item45ee6286db&vxp=mtr FYI the tusk flywheel puller has a nut on it that works perfect for that
