Yvon Ladouceur Posted April 26, 2014 Report Share Posted April 26, 2014 Pipes cpis Chariots head Vitos stroker crank 10mm Vitos 68mm piston 6mm offset K&N 1/2 box 35mm keihen air strikers Main jet 185 Pilot do not know yet. Altitude is from 100feet to 500 feet asl Mixining ratio 32:1 klozt r50 91 octane on my first mixing of 25 litres but didnt get to burn 25 litres yet can someone help Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
Yvon Ladouceur Posted April 26, 2014 Author Report Share Posted April 26, 2014 Top gear couldnt get rpm up n sputerd trew 1st a bit and trew the other gear also on high rpm except the 6th always down shifting back in 5tg Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
hp2000 Posted April 26, 2014 Report Share Posted April 26, 2014 Has this motor always ran on 91 octane ? Or did you buy it assembled and figured 91 oct was good enough ? Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
hp2000 Posted April 26, 2014 Report Share Posted April 26, 2014 You need to know kicking compression since you mentioned it had a meltdown already. Maybe its a race gas motor ? Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
Yvon Ladouceur Posted April 26, 2014 Author Report Share Posted April 26, 2014 The guy told me 94 but figured. 91 was ok for one time thing kicking compression have no clue i will have my piston from vitos in a few days n then al be doing more testing but i still need info on what type of gas i should be using n what type of mixing oil should i use also n what type of oil should i use for clutch side and what type of prestone should i use also Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
Yvon Ladouceur Posted April 26, 2014 Author Report Share Posted April 26, 2014 The guy where i am geting my stuff from piston looked like it was pre ignition Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
hp2000 Posted April 26, 2014 Report Share Posted April 26, 2014 Well if you had a melt down and seems it was rich then octane was your problem. Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
sleeper06 Posted April 26, 2014 Report Share Posted April 26, 2014 U need a banshee guy for help you have 1000 variables and no clue, you need to pressure test that motor , compression test, squish test. Without the tools to do do so its not gonna fix itself and its not gonna clear out. Either invest in tools and do some research on hear or your gonna blow this one up too Quote Link to comment Share on other sites More sharing options...
Yvon Ladouceur Posted April 27, 2014 Author Report Share Posted April 27, 2014 Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
n2otoofast4u Posted April 27, 2014 Report Share Posted April 27, 2014 Cheetah? Sent from my SCH-I545 using Tapatalk Quote Link to comment Share on other sites More sharing options...
n2otoofast4u Posted April 27, 2014 Report Share Posted April 27, 2014 10mil? Sent from my SCH-I545 using Tapatalk Quote Link to comment Share on other sites More sharing options...
n2otoofast4u Posted April 27, 2014 Report Share Posted April 27, 2014 Where are you from? I'm gonna guess not in the USA Sent from my SCH-I545 using Tapatalk Quote Link to comment Share on other sites More sharing options...
Yvon Ladouceur Posted April 27, 2014 Author Report Share Posted April 27, 2014 Pembroke ontario canada Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
Yvon Ladouceur Posted April 27, 2014 Author Report Share Posted April 27, 2014 Yes its a 10mm stroke by vitos Piston is 68mm with a 6mm offset pin Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
Yvon Ladouceur Posted April 27, 2014 Author Report Share Posted April 27, 2014 Porting done by Rocket porting Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
