Still not getting fuel? What else?
Ok, carbs are clean( boiled and spotless) , I have new Reeds, I have 125 compression and there is fuel in the carbs but it's not getting pulled through. What else can I check for? I've kicked it with choke and checked the plugs after and they're dry. If I put fuel in the head it will start and stay running?! Anyone else have this happen? This thing is driving me crazy
It runs great once I get it started!! Also I fired it up this morning( with some help) and I took the choke tube off while it's running and it revs up quite a bit,, put the tube back on and it idles down to where it should be. Is this normal??
Yes, because without tube you have created an air leak=lean
