Head oring set
mmohr423
you will have o-rings left over, use none of the lil ones around the studs, the domes you have with your Vitos head probably has an o-ring around the top of the dome that was designed to hold the dome in at assy. the o-ring in the top cover is for the water and I don't think a cool head kit has the dome o-ring, the Viton are the same as are the outer and top
