Brap_Brap_Banshee Posted April 21, 2014 Report Share Posted April 21, 2014 Hey i know this isnt a banshee question but i know the clutches are somewhat simular but the clutch arm/actuator just get bent when pulled on even a brand new actuator just got bent. I removed the clutch plates and it was still locked so i think it has to be the pushrod and ball? Just wanted to know if anyone has the same problem before and what it may be. Thanks in advance Sent from my LGMS500 using Tapatalk Quote Link to comment Share on other sites More sharing options...
Surfrjag Posted April 21, 2014 Report Share Posted April 21, 2014 If you cant get the pushrod out its likely mushroomed om the actuator side or welded inside the shaft. Means split the cases... Quote Link to comment Share on other sites More sharing options...
