Banshee has no spark
I was riding in the dunes this weekend, spun a donut at pretty high RPMs (not sure if that's the cause, just when it happened) and it spit and sputtered and quit. I pulled the plugs off and was not getting spark to either cylinder. I tried kicking it a few times and it would give a few thumps but nothing lasting more than a second. TORS has been deleted and the wires are still spliced well, bike is mostly stock. I figure its maybe a stator gone bad but where would be the best place to start tracking the problem. Also how can you test if the stator is what is bad. Any input would be great, Thanks.
Black to Yellow is lighting so that will only tell you if you have light power or not. Need to check the other wires to see if the ignition side is working or not.
