cerdmann Posted April 17, 2014 Report Share Posted April 17, 2014 Hey guys, I bought a 94 Banshee from a guy. I was not overall too worried about this machine when I bought it. I knew that it would take some work to get it running after it sat for 2 or 3 years. My problem is that after replacing the stator, pickup coil, CDI, ignition coil, plug wires, plug caps, and spark plugs I am still not getting any spark. I used the( http://www.dfn.com/agservices/elecfaq.html ) to check all of my electrical connections and found that everything has continuity including kill switch, key switch, wiring harness, etc... Do you guys know of anything else I should look into in order to get spark? Thanks, Cody Sent from my SCH-I545 using Tapatalk Quote Link to comment Share on other sites More sharing options...
bansheerider313 Posted April 17, 2014 Report Share Posted April 17, 2014 woodruff key broke? Quote Link to comment Share on other sites More sharing options...
wayne_smith97 Posted April 17, 2014 Report Share Posted April 17, 2014 Has the tors been eliminated? Quote Link to comment Share on other sites More sharing options...
Larry's Shee Posted April 17, 2014 Report Share Posted April 17, 2014 How do you know replaced parts were bad? Did you use new OEM parts? Quote Link to comment Share on other sites More sharing options...
03DMshee Posted April 17, 2014 Report Share Posted April 17, 2014 Look on frame under gas tank shifter side and make sure that if your TORS is gone to have that unplugged Quote Link to comment Share on other sites More sharing options...
Newcs222 Posted April 19, 2014 Report Share Posted April 19, 2014 Pull your wiring harness apart and check for bad connections. I has this problem before Quote Link to comment Share on other sites More sharing options...
