J-Madd Posted April 17, 2014 Report Posted April 17, 2014 Measure the bolt hole distance and I can measure my other twister and see if they are the same. I wanna say they are kx250, or kx125. I got my intakes from PPS. If they are the same I will find out what the actual OEM application is. Quote
ban565 Posted April 17, 2014 Report Posted April 17, 2014 http://67.199.65.66/twistercrankshaft/store/store_view.cfm?store_area_id=22&STORE_DEPT_ID=286 Quote
J-Madd Posted April 17, 2014 Report Posted April 17, 2014 CR125 it is then. I was sure it was KX, but I guess not. I'm wondering now if I should get the bigger intake adaptor and run the bigger reeds. I'm not sure about running bigger exhaust flanges on that small of a motor. Quote
RadarRacing Posted April 17, 2014 Report Posted April 17, 2014 Packard might have those as well. His prices on intakes and things have always been good. He recommended 44s on my motor but with the size of the stock size VF reeds I stuck with some carbs bored to 42.5mm instead. Quote
ban565 Posted April 18, 2014 Report Posted April 18, 2014 no adapter needed tp run the cr 125 reeds. I use bf on a 6 mil Quote
J-Madd Posted April 18, 2014 Report Posted April 18, 2014 The reeds hit the intake bridge on mine if you put them directly into the intake without the adaptor/spacer. Quote
ban565 Posted April 18, 2014 Report Posted April 18, 2014 might be a dffrerent version than mine. I bought mine in 2009 Quote
jay shafer Posted April 18, 2014 Author Report Posted April 18, 2014 Sent from my SGH-M919N using Tapatalk Quote
87sheerips Posted April 21, 2014 Report Posted April 21, 2014 If u guys need anything custom made, adapters etc I can help. Quote
alcoholbanshee Posted April 23, 2014 Report Posted April 23, 2014 My mini has cr125 cages, I have some extra stock cr cages with carbon fiber reeds if somebody needs some. I also have a set of big flnge ex. adaptors if somebody needs also Quote
