Measure the bolt hole distance and I can measure my other twister and see if they are the same. I wanna say they are kx250, or kx125. I got my intakes from PPS. If they are the same I will find out what the actual OEM application is.
CR125 it is then. I was sure it was KX, but I guess not. I'm wondering now if I should get the bigger intake adaptor and run the bigger reeds. I'm not sure about running bigger exhaust flanges on that small of a motor.
Packard might have those as well. His prices on intakes and things have always been good. He recommended 44s on my motor but with the size of the stock size VF reeds I stuck with some carbs bored to 42.5mm instead.
