Andreb84 Posted April 15, 2014 Report Share Posted April 15, 2014 decided to go with redline racing for my 421 serval build.im going to send my cases in to get it port matched and i was thinking since its there should i go ahead and have them do the pro-mod transmission service bottom line i would like to know from someone with experience if its actually worth an extra $200 Quote Link to comment Share on other sites More sharing options...
sheerider11 Posted April 15, 2014 Report Share Posted April 15, 2014 Yes. Not even a question. It should be done to every banshee from piped to fully built. They all need attention in the trans. A pro mid is perfect for any weekend warrior. If your not dragging it the best upgrade you can do. I beat the hell out of mine. Hasn't missed a beat. Wot shifts, back loads, slamming on the shifter through the whoops, everything. Do it, then you'll wonder why you never did. Quote Link to comment Share on other sites More sharing options...
Surfrjag Posted April 15, 2014 Report Share Posted April 15, 2014 You better do it... Quote Link to comment Share on other sites More sharing options...
Andreb84 Posted April 15, 2014 Author Report Share Posted April 15, 2014 Yes. Not even a question. It should be done to every banshee from piped to fully built. They all need attention in the trans. A pro mid is perfect for any weekend warrior. If your not dragging it the best upgrade you can do. I beat the hell out of mine. Hasn't missed a beat. Wot shifts, back loads, slamming on the shifter through the whoops, everything. Do it, then you'll wonder why you never did. thats pretty much how i ride its about 50/50 trail/drag....nothing serious its not like im putting money on the line is there a reason drag racing is an exception?? Quote Link to comment Share on other sites More sharing options...
sheerider11 Posted April 15, 2014 Report Share Posted April 15, 2014 thats pretty much how i ride its about 50/50 trail/drag....nothing serious its not like im putting money on the line is there a reason drag racing is an exception?? most drag racers go for an override. Not saying you can't trail one. But for an average rider a pro mod will be more then enough. I can shift with just a little let off of the throttle easily. Quote Link to comment Share on other sites More sharing options...
Finch Posted April 15, 2014 Report Share Posted April 15, 2014 pro mod for sure i opted for it when he did my serval. Quote Link to comment Share on other sites More sharing options...
bluebanshee98 Posted April 15, 2014 Report Share Posted April 15, 2014 Pro mod ftw! Worth every penny and then some Quote Link to comment Share on other sites More sharing options...
Andreb84 Posted April 15, 2014 Author Report Share Posted April 15, 2014 most drag racers go for an override. Not saying you can't trail one. But for an average rider a pro mod will be more then enough. I can shift with just a little let off of the throttle easily. sounds good thanks for the input..is there anything else i can do while its there lol i would have saved myself alot of money if i just did shit right the 1st time dont mind paying if its worth it Quote Link to comment Share on other sites More sharing options...
sheerider11 Posted April 15, 2014 Report Share Posted April 15, 2014 All new shit. Like a pressure plate, hub, clutch, clutch cable, billet basket, shift shaft modded, shift pro kit, and eccentric screw. Tell cam to put the heavy duty bushings and heavy duty backing plate on the basket as well. All of that will have you sorted out for quite some time. Quote Link to comment Share on other sites More sharing options...
Andreb84 Posted April 15, 2014 Author Report Share Posted April 15, 2014 All new shit. Like a pressure plate, hub, clutch, clutch cable, billet basket, shift shaft modded, shift pro kit, and eccentric screw. Tell cam to put the heavy duty bushings and heavy duty backing plate on the basket as well. All of that will have you sorted out for quite some time. i should be good to go then i already bought a hinson basket with pressure plate,EBC heavy duty clutch plates, stainless steel cables all around and the shift pro kit comes with the pro-mod tranmission...i'll ask about the other stuff while im at it though Quote Link to comment Share on other sites More sharing options...
Zillaguy Posted April 15, 2014 Report Share Posted April 15, 2014 Make sure his pro-mod has the shift drum modded with a bearing.. also have the cases modded so the shift shaft is on bearings too... My pro-mod is one of the best mods i've done to my bike... I can shift at WOT without letting off the throttle, and no missed shifts.. With this trans it takes zero effort to upshift, just a blip of the clutch, and it shifts like butter. 1 Quote Link to comment Share on other sites More sharing options...
wfobasheeboy Posted April 15, 2014 Report Share Posted April 15, 2014 I am running a redline pro mod and love it. I would never look back. Quote Link to comment Share on other sites More sharing options...
Andreb84 Posted April 15, 2014 Author Report Share Posted April 15, 2014 Make sure his pro-mod has the shift drum modded with a bearing.. also have the cases modded so the shift shaft is on bearings too... My pro-mod is one of the best mods i've done to my bike... I can shift at WOT without letting off the throttle, and no missed shifts.. With this trans it takes zero effort to upshift, just a blip of the clutch, and it shifts like butter. That sounds like it would tear your tranny to shreds after a while...didn't know that you could do that all I knew was that it would make your gears easier to find Great forum you learn something new everyday Quote Link to comment Share on other sites More sharing options...
