Adamjf2001 Posted April 14, 2014 Report Share Posted April 14, 2014 I'm sure this a dumb question!! But I can't find anything on here about it. If u change needle postion do u have to change any of ur jets Quote Link to comment Share on other sites More sharing options...
special06shee Posted April 14, 2014 Report Share Posted April 14, 2014 Depends on where you want to make jetting changes. Needle adjustments will effect from roughly 1-4 to 3/4 throttle jetting Quote Link to comment Share on other sites More sharing options...
sleeper06 Posted April 14, 2014 Report Share Posted April 14, 2014 Thats actually not a diumb question I get worse than that eveyday. Get your main dialed in , wide open pulls checking plug color. Then mess with your needle where are you at now with the jetting Quote Link to comment Share on other sites More sharing options...
Adamjf2001 Posted April 14, 2014 Author Report Share Posted April 14, 2014 Well not sure I bought it a few moths ago only road three times!!!! I work out of state ill know more this weekend when I go home going to take carbs apart and clean!! It is real boggish from Take off to 1/2 throttle then 1/2 on it screams!!! Atoka native sugested to check needle and pilot jets . So that what I'm going to do over east plus a plug chop Quote Link to comment Share on other sites More sharing options...
RadarRacing Posted April 14, 2014 Report Share Posted April 14, 2014 I see tons of bikes with just stupid rich needle settings. They are dogs in the low-mid throttle position. They are much more fun when the needles and jetting is spot on. Your bike may be rich on the main too. If the main is rich it will be sluggish and clean up when going thru the gears but then may burble up top from being rich. To answer your question about needle position effecting any other circuits. Yes they do but only a small amount. If for example you had a bike jetted right on the edge perfectly on the mainjet then leaning out the needle a clip or two would be bad. Otherwise it is really 1/4-3/4 like Special said. Quote Link to comment Share on other sites More sharing options...
Strm Trpr Posted April 14, 2014 Report Share Posted April 14, 2014 To answer your question about needle position effecting any other circuits. Yes they do but only a small amount. If for example you had a bike jetted right on the edge perfectly on the mainjet then leaning out the needle a clip or two would be bad. Otherwise it is really 1/4-3/4 like Special said. Hopefully that should be very apparent to anyone in this hobby... Here's a diagram that depicts what jets affect which circuits. Quote Link to comment Share on other sites More sharing options...
Adamjf2001 Posted April 14, 2014 Author Report Share Posted April 14, 2014 Thanks guys I'm going to clean them up good!! I'm going to adjust the air screws first then go from there Quote Link to comment Share on other sites More sharing options...
Strm Trpr Posted April 14, 2014 Report Share Posted April 14, 2014 Take them apart, one at a time so you don't inadvertantly mix parts. Note what jets you currently have in them, ie., pilots, needles, needle clip position and mains. Use carb cleaner and wear safety glasses. Pull the floats off and the needle of the fuel inlet needle and seat. Use some toothpaste on a q-tip to polish the seat. Use compressed air to blow every orifice out completely. If you're talking about stock carbs, i recommend ordering new OE bowl gaskets and switch out the bowl screws to allen heads. Quote Link to comment Share on other sites More sharing options...
Adamjf2001 Posted April 14, 2014 Author Report Share Posted April 14, 2014 They are supposed to be bigger carbs going to measure this weekend stocks are 26 mm correct the guy I got it from said these are 34s Quote Link to comment Share on other sites More sharing options...
Adamjf2001 Posted April 20, 2014 Author Report Share Posted April 20, 2014 Alright guys my main jet is 150. My slow jet is is 48 and the needle clip is the third from the bottom I'm at 800 ft with fmf gold with power core twos right now is this correct Quote Link to comment Share on other sites More sharing options...
Adamjf2001 Posted April 21, 2014 Author Report Share Posted April 21, 2014 My carbs sudco keihin 35mm !!! There websit says starting out jet setting is 160 and 68 Quote Link to comment Share on other sites More sharing options...
RadarRacing Posted April 21, 2014 Report Share Posted April 21, 2014 Adam , 150s could very well be just fine for jets in 33 or 35mm keihin pwks. Honestly you are lucky as heck to be from atoka. Go to the atoka drags some weekend for a test and tune and have someone help you. You can not jet a bike off the sudco site. It has to be ridden and usually someone knowledgeable can show you alot in 10 mins if you are willing to listen. Quote Link to comment Share on other sites More sharing options...
Adamjf2001 Posted April 21, 2014 Author Report Share Posted April 21, 2014 I'm going to go to the sand drags in May and as far as jets and stuff is there a place that U guys recommend to buy from or do I have to buy from sudco thanks for the help Quote Link to comment Share on other sites More sharing options...
FullThrottle_06' Posted April 21, 2014 Report Share Posted April 21, 2014 Call Jeff @ Farm and Sand Toys. Tell him what setup your running (engine, pipes, carbs) and he will point you in the right direction and also have the parts you are looking to order. Quote Link to comment Share on other sites More sharing options...
