Leaky pingel.
Mine didn't leak fuel outside of the valve, but when i shut it off, one side would still flow some fuel. Contacted Pingel and they fixed it up for me.
Where is yours leaking?
If your seal is torn or old cracked and brittle just replace that or try to seal it up better.
I put some silicone stuff on mine that let it seal up better at the tank as well, it's safe with fuels. I'll see if i can remember the name of the sealant. But anything safe for fuel will be sufficient.
Mine came with a thick rubber gasket as well. Over time I think they just break down. I run avgas and it's a pretty dry fuel, so it might break it down I wee bit faster.
Anyways just try a light coat of some silicone on both sides that can be used with petroleum.
Sent from my shed.
