817DMX Posted April 11, 2014 Report Share Posted April 11, 2014 (edited) Who has remote start nuts, for banshee , that I can buy, any info would be great thanks? or if you have one or 2 I can buy call me 253-651-4379 Edited April 11, 2014 by 817DMX Quote Link to comment Share on other sites More sharing options...
SOUTHTHIRTY Posted April 11, 2014 Report Share Posted April 11, 2014 Precision power sports makes them..I'm not sure if they stock them. Quote Link to comment Share on other sites More sharing options...
m671054 Posted April 11, 2014 Report Share Posted April 11, 2014 Better have them install it. if not centered up will cause balance issued. if its for a 817dmx that will kick start once dialed in properly. you just cant pussy foot it. Quote Link to comment Share on other sites More sharing options...
J-Madd Posted April 11, 2014 Report Share Posted April 11, 2014 PPS. X2. If you decide to kick it get a dyna and retard the timing at low RPMs. It only takes one time to break a lot of shit. I remote start my 650 cc. Kicked it at the shop with tennis shoes and broke idler gear, cover, kicker gear. Turned it on its side and left it home that race. Quote Link to comment Share on other sites More sharing options...
bansheepuller Posted April 11, 2014 Report Share Posted April 11, 2014 You can also get ahold of Dennis at Packard Enterprises. 1-801-451-6142 Quote Link to comment Share on other sites More sharing options...
m671054 Posted April 12, 2014 Report Share Posted April 12, 2014 PPS. X2. If you decide to kick it get a dyna and retard the timing at low RPMs. It only takes one time to break a lot of shit. I remote start my 650 cc. Kicked it at the shop with tennis shoes and broke idler gear, cover, kicker gear. Turned it on its side and left it home that race.what ratio primaries? this affects the possibility of kickstarting a big motor as well. Quote Link to comment Share on other sites More sharing options...
Nieskes Posted April 12, 2014 Report Share Posted April 12, 2014 I have one on a pvl if your looking to buy used. Quote Link to comment Share on other sites More sharing options...
locogato11283 Posted April 12, 2014 Report Share Posted April 12, 2014 I've been kicking my 18DM with OEM primary ratio gears for years. I broke one kicker gear back in 2010. You HAVE to commit and kick them all the way through. If you do, they will fire right up. Quote Link to comment Share on other sites More sharing options...
n2otoofast4u Posted April 12, 2014 Report Share Posted April 12, 2014 Mattoon also makes them. However, if you are running the hill or a weekend warrior drag racer I'd learn how to kick! Sent from my SCH-I545 using Tapatalk Quote Link to comment Share on other sites More sharing options...
J-Madd Posted April 12, 2014 Report Share Posted April 12, 2014 what ratio primaries? this affects the possibility of kickstarting a big motor as well. 2.81 primaries. Close enough to stock to not matter. Quote Link to comment Share on other sites More sharing options...
817DMX Posted April 12, 2014 Author Report Share Posted April 12, 2014 (edited) I run a lot of compression and its a s.o.b. to kick and Im 240lbs, I was breaking kick gears I put a billet in, I was busting idle gears, so I put compression releases in the head , but I want to just have remote start setup for backup , I do run the hill that's why im working this out, my 18dm was nothing compared to this 85mm dmx, thanks for all the replys. Edited April 12, 2014 by 817DMX Quote Link to comment Share on other sites More sharing options...
