Kompulsive Concepts Posted April 10, 2014 Report Posted April 10, 2014 I'm now offering harness and stator adapters for those wanting to use a different year harness or stator on their Banshee 87-94 Stator & Harness to 3GG-10 CDI box (97-06) 95-96 Stator & Harness to 2GU-50/51 CDI box Square Plug Stator (95-06) to Round Plug Stator (87-94) Use 95-96 harness with 3GG-10 CDI box (97-06) $20 for single adapters $30 for double If you have mismatched electronics that you would like to use and don't see a solution listed here, don't hesitate to ask, I'll make it work (no hacking required) Sent from the Electric Chair Quote
special06shee Posted April 10, 2014 Report Posted April 10, 2014 Good shit!!! For these prices why would anyone even dick with wiring?? Bump for a CLEAN, SIMPLE, and WORKING product!! And thanks for my custom harness!! Quote
tdod101 Posted April 10, 2014 Report Posted April 10, 2014 What a fantastic concept, I might pm you about some custom wiring Quote
Banshee SE Posted April 15, 2014 Report Posted April 15, 2014 very good option for those headaches!! Quote
Kompulsive Concepts Posted June 30, 2014 Author Report Posted June 30, 2014 2 stator adapters with wiring for lights. Both are for round plug stators (87-94) allowing to use 95+ electronics. The adapter on top has PVC tubing covering it & heat shrink is covering the adapter on the bottom. Wiring for lights can be added at no extra charge to any stator adapter. Sent from the Electric Chair Quote
Kompulsive Concepts Posted July 14, 2014 Author Report Posted July 14, 2014 Here is an adapter I made for an 95-01 OEM control switch. With this specific adapter, an 02-06 can be used. I can do adapters for any year except 95-06 switches to be used with 87-94 harnesses. I can make these with all 6 wires or just the wires you need and cover them with heat shrink or high temp PVC tubing. It seems like used OEM control switches are usually available and relatively cheap, but if you would be interested in one, $20 will get one to your door. Feel free to comment or message with any other ?s you may have. Sent from the Electric Chair Quote
Meth Cub Posted July 26, 2017 Report Posted July 26, 2017 Hello I need two adpaptors.. I need one that will make a round plug stator fit a square plug wire harness and I also need one that will make a square plug stator fit a round plug wire harness. If available. How much for both? Quote
hoppedupandcutdown Posted July 26, 2017 Report Posted July 26, 2017 5 minutes ago, Meth Cub said: Hello I need two adpaptors.. I need one that will make a round plug stator fit a square plug wire harness and I also need one that will make a square plug stator fit a round plug wire harness. If available. How much for both? It'd be best to message him here or on Facebook https://www.facebook.com/kompulsiveconcepts/ Quote
Guest Arkell Posted March 29, 2019 Report Posted March 29, 2019 I have a 1995 yamaha moto4. I just replaced the stator but the connections are different. Top picture is new connectors and bottom is connectors to the yamaha. How much you charge for this? Quote
hoppedupandcutdown Posted March 30, 2019 Report Posted March 30, 2019 Here is his personal FB link, looks as if his business one is down https://www.facebook.com/K0mpulsiveconcepts?__tn__=%2CdK-R-R&eid=ARDJsHBPT6Ssq-N5iLyK9QBsNpCeQrHcKbR1DJuiv5YMU5-gvVpyvxPLpcLYWou0ZRfcSiP5GnW7fSvf&fref=mentions Quote
Guest MBwierdness$ocal Posted May 24, 2019 Report Posted May 24, 2019 Can 95-96 cdi's be used with adapter connector On 87-94 harness Quote
