what coolant to run?
That's all i run is the cheapest no name brand 50/50 from walmart. I used to run engine ice.....junk doesn't do anything but make your wallet lighter. Ive checked temp difference with a laser temp gauge, and an in-line temp gauge with barely any change at all if any.....50/50 elcheapo is the way to go.
Same with the trans, i use the cheapest no name brand ATF Type F from walmart. I use it all season long then change it out at the end of the season once. Always good to go for $3.50 a bottle.
I always use the good shit in my motor though. Amsoil Dominator @ 50:1 and 100LL.
Just grabbed both trans and coolant fluid for $20 bux couple days ago at walmart........DEEECENT!!!!
My over flow bottle is deep in the land fill a decade ago.
I just use compressed air to get it all out. Then run water through.... Then compressed air again.
20psi or so is enough. Don't look in the hole lol
Sent from my shed.
