themechanic Posted April 6, 2014 Report Share Posted April 6, 2014 I have had this bike apart for a few seasons now and finally have the parts to put it together and for the life of me i cant remember where it was routed and what it hooked too. Cant find it in the manual either and parts micro fiche doesn't show it at all Quote Link to comment Share on other sites More sharing options...
mxturd Posted April 6, 2014 Report Share Posted April 6, 2014 It routed up to a T i believe. Right under the tank Quote Link to comment Share on other sites More sharing options...
do-work-son Posted April 6, 2014 Report Share Posted April 6, 2014 http://www.ebay.com/itm/Banshee-Clutch-Cover-Vent-Block-off-Plate-/110747369144?_trksid=p2054897.l5658 This works too Quote Link to comment Share on other sites More sharing options...
sheerider11 Posted April 6, 2014 Report Share Posted April 6, 2014 I route it to the ground Quote Link to comment Share on other sites More sharing options...
Zillaguy Posted April 6, 2014 Report Share Posted April 6, 2014 I bought a billet plug and plugged mine. There is no need for it when you have a vent on the rear of the cases... Both are transmission vents... Quote Link to comment Share on other sites More sharing options...
themechanic Posted April 6, 2014 Author Report Share Posted April 6, 2014 Going up to a tee makes sense, the only hose i had in the box had clamps on both ends. Im pretty down with blocking it to clean up the appearance abit though Quote Link to comment Share on other sites More sharing options...
RagunCajun Posted April 6, 2014 Report Share Posted April 6, 2014 I believe i put a old small bolt in mine and clamped it off years ago. Quote Link to comment Share on other sites More sharing options...
2004LEBanshee Posted April 6, 2014 Report Share Posted April 6, 2014 It goes up to a t that os above the carbs. I filled mine with solder and siliconed the hole. Quote Link to comment Share on other sites More sharing options...
Coupelx Posted April 6, 2014 Report Share Posted April 6, 2014 you can cap it off. alot of us do, mine has been that way for along time. The motorcycles had an oil pump there. Quote Link to comment Share on other sites More sharing options...
