Motor rebuild
I blew the stock motor and am doing my rebuild now. I mostly do trail and motocross so I'm thinking a trail /woods port. 65mm bore ,Wiesco pistons ,true and weld my crank,cool head and domes, port my cases. ......I run stock cards,pods,vforce4s and t5s......what are your thoughts on this set up? Where should this put me in hp and would a 4mil crack be better bTnx in advance for any input fellas.
a 4 mil crank will do you alot of good just make sure you run it up in the head, careful on porting and run a dome based on your altitude and gas supply, for the riding your doing forget HP worry about torque and thats what you'll get with a 4 mil and stroker domes
