Need little help with jetting
Have a fresh top end with just barely enuf time for break in. Stock bore .Wiseco pro-lites. 21cc domes. Vf4 reeds. T6 pipes. "i know they suck but got brand new set for 300$ "stock mikuni carbs. Tors removed. Stock box. lid removed pro flo adapter with K&n filter with outerwear. Currently at 150 and 152 psi. Elevation is from 600ft to 1300ft. Mixing 32:1 with 93 octane. Stock pilots stock needle on 5th clip 1.5 turns out and 280 mains. Bike starts just doesn't wana idle cold . Do i need to up the pilot to maybe a 27.5 or go on to a .30 To cure the idle problem? Haven't really got to open up to get on the main jet because i smoked the clutch within 30 mins after the build. but I'm pretty sure i need to fatten both main and pilots?? Temp is bout 60 to 70 here in middle Tn rite now .Thanks for any input
