Transmission dog ear mod
The baskets stock but mint I'm not to concerned with neutral it's more being able to shift to third while climbing
where you climb at? Is your eccentric screw adjusted properly? Are you sure your foot is actually coming off the shifter completely before trying to upshift again? Move the shifter leveler up one set of splines and see if that helps some.
one spline makes a big difference, one spline up on mine is way to high.
I climb in pa. As far as I know everything is spot on. It shifts mint on the flat WOT but won't shift for shit on a load. I've had my buddies try it to see if I was crazy but it was the same thing. That's why the dog ear mod should help correct?
