From a 4mil cub to a 10mil.
Okay I need some input on this because im hearing alot of different things. So I was planning to go from a 4mil cub, 68mm to a 10mil. I know to do it I need my cases trenched & a new crank. But my question is do I need a spacer plate so the port timing will match up? What do you guys think about it? Any input will help.
Thanks!
Sent from my SCH-I535 using Tapatalk
It might be possible. ive had a 4mill cheetah that we turned into a 10mill. it used non normal parts and had lots of machine work done. look on cp webstie and compare dimensions from a 4-10 cylinder. pay attention to overall cyl height first.
^^ I am with these guys. Stick with the 4 mil or start over. You wil be out maybe what $400-600 by selling your 421 used and getting a new 10 mil cyl. Honestly if you think it runs well now it will only run worse. If it runs like ass then maybe someone can fix it into a half assed 10 mil for ya. Not hatin , just answering your question.
do yourself a favor and stick with what you got if your asking why
OP if post like that bothers you, get with a forum sponsor and they will help you. They helped me go from 4mil to 10mil and didnt know all the technical stuff off hand.
