Coolent Bottle Relocation
whobanshee
Currently, mine is just zip tied to mount temporarily. So if you need a quick fix, you can do that. However, it looks like you can get an "L" bracket and mount it from the a mounting tab (the one mine is currently zip tied on, I'm pretty sure it was a mount for the air box) to the resivor. I too was wondering is there is a better way to do this, but from looking at it, the "L" bracket looks best to me.
It's the best thing I've done to the cooling system. It use to spit coolant and I'd have to fill it all the time. It would get low if I went on a whole day ride. I'd even worry if it were getting to low.
I use to think it was overheating, but it wasn't. It was actually just siphoning itself out because the coolant bottle sits so high compared to the radiator. I straped it up under the front and rerouted the hose. Didn't have to refill it once last summer.
A lot of peoplel eliminate the coolant bottle all together and don't have any trouble. I decided to keep mine so it can pull some in when it need it. And yes, it works that way. Holyman (I believe) proved that.
If you move the coolant bottle to the front, it is important to keep the coolant bottle overflow tube routed up the frame near the upper steering stem mount and then back down. If you simply route the overflow tube straight down to the ground, it will empty your coolant bottle in a single ride. By having the overflow tube go up first, and then down, it will allow the coolant that gets splashed into the tube to drain back into the tank, Instead of directly onto the ground. If you follow the directions on the Banshee Zone website, then you won't have this problem. I just don't always follow directions well.
Here is the link to the directions:
http://kuoi.asui.uidaho.edu/~john/tips.html
I believe this is holyman's bike, I don't remember anymore. Whosever it is, I hosted these pics, so here you go!!
And here is my setup, I don't have a removeable cap like that, I just cut a hole, and put a rubber grommet in there...
I have my bottle zip tied to the brace in the front of the frame. Holyman's (Or whosever that one is) has an aluminum andle bracket that he made himself....
yea what mrmatt said lol i made the mistake of putting my hose straight down without thinking and it all splashed out every last bit of it. lol my bad didnt hurt anything. im going to remove it compleatly and put the overflowabove my pipe so it steams if it overheats i also have installed the BHQ officail meat thermometer temp guage mod lol
