Need help removing axle nuts
Newcs222
Heat them with a torch, Mapp gas will work fine... Then turn them with a pipe wrech, turn the outer one first.. There is a special wrench for those, it's called a "spanner wrench".
  • Like 1
If you're not re-using them (I wouldn't) Just sawzall 3/4 of the way thru them. Then put the heat and wrenches to it.
  • Like 1
