Little help with DIY grit blasting please? *See pics*
Rapture
Im having ago at grit blasting a few painted metal parts.
The large dark grey area is the blasted section and the shiny patches on the dark grey is where i have gone over it quick with a bit of 400 git paper.
Basically, im not sure if the grit blasting is taking off all of the paint OR it is taking off all the paint but just leaving a dull slightly pitted surface. And then by rubbing it down with 400 brings in the shine?
Is the metal ment to be all shiny straight after blasting?
Considering the media is 180g at best, the 400 would be like the next stage if you were polishing. Blow it off when done, maybe clean with paint thinner, then tack rag, prime/paint done.
Cool. Not looking to polish just repaint. The 400 was just a test to see if i had gone right down to the metal with the blasting.
Was thinking about trying some glass grit to see if it leaves less dusty residue?
