uman1030 Posted March 23, 2014 Report Share Posted March 23, 2014 I would check out how you got shocked. If touching it at idle zapped ya then at high rpm it may be arching to ground and cutting out. Quote Link to comment Share on other sites More sharing options...
xmarlboromanx Posted March 23, 2014 Author Report Share Posted March 23, 2014 (edited) Maybe I'll go out now while its dark and see if I can see it arc.... And if I don't get this figured out I just might need some more rope.... Edited March 23, 2014 by xmarlboromanx Quote Link to comment Share on other sites More sharing options...
Infamous039 Posted March 24, 2014 Report Share Posted March 24, 2014 (edited) If you got zapped by the spark boot either you coil is bad or coil boots need to be replaced you shouldn't get shocked by that. Your definitely to fat on the main jet, drop it to a 260 with clip on middle. Definitely replace that coil with a new one. Bogator Edited March 24, 2014 by Infamous039 Quote Link to comment Share on other sites More sharing options...
xmarlboromanx Posted March 24, 2014 Author Report Share Posted March 24, 2014 (edited) OK just went out with new plugs I see a blue spark coming from where the thin black wire plugs into the coil under the handle bars.. I know the other day part of the wire was showing so I put some E tape on it guess I didn't do a good job lol.. So I'm guessing that would be my problem? Edited March 24, 2014 by xmarlboromanx Quote Link to comment Share on other sites More sharing options...
xmarlboromanx Posted March 26, 2014 Author Report Share Posted March 26, 2014 Turned out to be a combo of a bad Float needle and a very loose thin black wire that plugs into the coil. Quote Link to comment Share on other sites More sharing options...
