swilerc Posted March 23, 2014 Report Share Posted March 23, 2014 Ok I took apart my casing and found out that one connecting rod was busted, and the other was fine. Is there a way to put a new connecting rod on or do i have to buy a whole new crankshaft? If i do have to buy a new crankshaft what is the best. Quote Link to comment Share on other sites More sharing options...
trickedcarbine Posted March 23, 2014 Report Share Posted March 23, 2014 I would seek out another stocker and get it trued and welded. Quote Link to comment Share on other sites More sharing options...
ban565 Posted March 23, 2014 Report Share Posted March 23, 2014 Hotrod crank welded and trued Quote Link to comment Share on other sites More sharing options...
Finch Posted March 23, 2014 Report Share Posted March 23, 2014 new hot rods crank is usually cheaper then a rebuild Quote Link to comment Share on other sites More sharing options...
swilerc Posted March 23, 2014 Author Report Share Posted March 23, 2014 if i do that should i go ahead and get new pistons? Quote Link to comment Share on other sites More sharing options...
swilerc Posted March 23, 2014 Author Report Share Posted March 23, 2014 what are the differences in 115mm rods and 110mm rods?? Same question with 4mm and 5mm cranks? Quote Link to comment Share on other sites More sharing options...
RadarRacing Posted March 23, 2014 Report Share Posted March 23, 2014 If you have a broken rod you should basically do crank , pistons , seals and basically go thru it. A crank will be under $500 add $200-300 approx for pistons and gaskets , seals. Quote Link to comment Share on other sites More sharing options...
swilerc Posted March 23, 2014 Author Report Share Posted March 23, 2014 (edited) OK what brands would you prefer? and would you do a bigger crank and pistons then or just leave it stock? Edited March 23, 2014 by swilerc Quote Link to comment Share on other sites More sharing options...
Larry's Shee Posted March 23, 2014 Report Share Posted March 23, 2014 What's your budget? What caused rod to break? How did it run before it blew? What other mods do you have? What are your short and long term plans for this? Quote Link to comment Share on other sites More sharing options...
swilerc Posted March 23, 2014 Author Report Share Posted March 23, 2014 Budget: Cheap but reliable Cause: I have no idea when i get a chance i'll take pictures Before: It ran like a champ Mods: it was bored over .01 and exhaust Plans: A little racing, dunes, and trails Quote Link to comment Share on other sites More sharing options...
swilerc Posted March 24, 2014 Author Report Share Posted March 24, 2014 i need answers asap Quote Link to comment Share on other sites More sharing options...
n2otoofast4u Posted March 24, 2014 Report Share Posted March 24, 2014 Answer: READ MORE 1 Quote Link to comment Share on other sites More sharing options...
Larry's Shee Posted March 24, 2014 Report Share Posted March 24, 2014 .010 bore is not a mod. remove snorkel is. air box mods, carbs, pipes, anything performance improving Quote Link to comment Share on other sites More sharing options...
RonnieMac69 Posted March 27, 2014 Report Share Posted March 27, 2014 hot rods crank welded and trued is around $600 brand new , I just put one in my banshee works great weisco piston set is around 300 also works great , I have no problems and I did the rebuild myself , replace all gaskets and seals aswell Quote Link to comment Share on other sites More sharing options...
sheerider11 Posted March 28, 2014 Report Share Posted March 28, 2014 hot rods crank welded and trued is around $600 brand new , I just put one in my banshee works great weisco piston set is around 300 also works great , I have no problems and I did the rebuild myself , replace all gaskets and seals aswell You got fucking RAPED on that crank. Quote Link to comment Share on other sites More sharing options...
