lian Posted November 12, 2003 Report Posted November 12, 2003 ok i bought some powercores 2 and how many screw turns out would i have to do for them for the jetting \and if i bolt the stock filter to the air box can i run without the lid or is the filter design to crappy thanks lian Quote
Banchetta Posted November 12, 2003 Report Posted November 12, 2003 ok i bought some powercores 2 and how many screw turns out would i have to do for them for the jetting \and if i bolt the stock filter to the air box can i run without the lid or is the filter design to crappy thanks lian You can screw it to the air box, but I'd still consider buying the flange...you might want to silicone the stock flange before screwing or bolting it on...the air screws are up to you...you have to decide where the best position is for throtte response...just do both sides evenly..you might want to go up a few sizes on the mains also....try a 250 and do a plug check.. Quote
