JCSO605 Posted March 20, 2014 Report Share Posted March 20, 2014 I want to run alky but I'm about to give up. I have 38 to 39.5 mikunis with 116 tube drilled w/ powerjets on a 10 mil cub. It had 60 pilots and needle clip was 2 nd from top. It would run but I had to give it throttle to crank. Had to kick it 20+ times. I went to a 50 pilot and moved clip to 3rd air screws set 1 1/2 turns fired right up and idled I made about four 200 foot passes and killed it. Got it up to about 165 degrees from then on it was 20+ kicks to get it running and having to give it throttle again. I'm at 200asl 75 degrees 176 psi Any help on which way to go would be appreciated. Quote Link to comment Share on other sites More sharing options...
JCSO605 Posted March 20, 2014 Author Report Share Posted March 20, 2014 I'm noticing a lot of people running 35 and 45 pilots at my elevation Quote Link to comment Share on other sites More sharing options...
