Here's my info
2001 banshee
Just installed new hot rod crank stock stroke
New top end wiseco pro light 65.50mm
Stock 26mm carbs
Stock intake's
Air box no lid
Toomey T-5 exhaust
650 elevation
Trinity stage IV porting
13-41 sprockets
Bike will be a dunner/aggressive trail/ play on pump gas 91oct here
Any advice would be sweet just looking for a ball park this is a new build and I need to order a jet kit but I have never ran any of the Trinity Porting stuff and still not sure on the dome size I need to run with the setup the duration is 188 on the cylinders and software says 24cc domes will run 138 psi And
23cc domes will be 145psi
Hell I was thinking around 20cc with the porting any ideals
I dident check seeing its all stock stroke and cylinders now if it was a high compression reading I could adjust it to less with base gasket but i dont think there's a way to adjust to make less squish is there
I'm going back to get the 22 domes and put back in a check it I had passion bore the cylinders and there good also the ring end gap was spot on at 10thou so now I'm heading to a buddy's house to pick the 22's again and check squish easy pezy
I'm thinking it might be thicker but don't know
Well I checked squish with a pice of sod I have here that's .062 and piston don't even hit it so now I'm going to the auto parts house and gona get a little thicker sod so I guess I might be looking at new base gaskets after I measure what I got now?
Ok average was 58-60 so ? Tear down and check thinness I guess never checked I'm running the kit off eBay that came with hit rod crank and wiseco 65.50mm pistons and gaskets wtf!! Needs to be done by Tommorow
