bansheeboy01 Posted March 19, 2014 Report Share Posted March 19, 2014 what size stroker crank can I run with stock cylinders and with what size coolhead domes? Quote Link to comment Share on other sites More sharing options...
bansheeboy01 Posted March 19, 2014 Author Report Share Posted March 19, 2014 on pump gas Quote Link to comment Share on other sites More sharing options...
Starwriter Posted March 19, 2014 Report Share Posted March 19, 2014 The size crank you can run is directly proportional to the credit limit on your Visa card and indirectly proportionate to the size of your Johnson. 2 Quote Link to comment Share on other sites More sharing options...
tdod101 Posted March 19, 2014 Report Share Posted March 19, 2014 The size crank you can run is directly proportional to the credit limit on your Visa card and indirectly proportionate to the size of your Johnson. And how much bitching your ears can take from the wife Quote Link to comment Share on other sites More sharing options...
trickedcarbine Posted March 19, 2014 Report Share Posted March 19, 2014 what size stroker crank can I run with stock cylinders and with what size coolhead domes?7mm stock cyls friggin rip! I've seen/heard about a few 10mm stock cyl set ups but they all come with way more issues and problems. 1 Quote Link to comment Share on other sites More sharing options...
trickedcarbine Posted March 19, 2014 Report Share Posted March 19, 2014 what size stroker crank can I run with stock cylinders and with what size coolhead domes?7mm stock cyls friggin rip! I've seen/heard about a few 10mm stock cyl set ups but they all come with way more issues and problems. Quote Link to comment Share on other sites More sharing options...
m671054 Posted March 19, 2014 Report Share Posted March 19, 2014 realisticly 7mm. Technically you could probably do 14 but would need spacer welded to tops of cylinders and new sleeves for the setup. not cost effective and wouldnt perform as well as a aftermarket cylinder. this would not be an off the shelf type thing. doubt many builders would even do it nowadays. but you asked.you can do a 14mm wampus if your trying to look stock but anyone with half a clue would know whats up Quote Link to comment Share on other sites More sharing options...
topfuel! Posted March 19, 2014 Report Share Posted March 19, 2014 I'm a fan of the 7mm stock cyl, total sleeper and 100+ hp easy. My next build will be 7mil stock cyl. Quote Link to comment Share on other sites More sharing options...
gst_r Posted March 19, 2014 Report Share Posted March 19, 2014 I used to have a 7mm stock cylinder!! great engine !!! Here beating a supposed 8mm raptor (12mm) http://www.youtube.com/watch?v=aMX_4q62jr0 Quote Link to comment Share on other sites More sharing options...
