BitchenBanshee Posted November 12, 2003 Report Share Posted November 12, 2003 I finally got a set of aftermarket lights for the shee. The problem is that my harness was cut before I got the bike. The switch is gone and replaced with a teather switch. The lights I have are a two wire filament. There are three wires on the shee and I assume that there is one ground, one for dims, and one for brights. I want to just use the brights. Anyone know which wire if for brights. Can anyone offer any expertise on how to wire a switch up for these! Thanks!! Quote Link to comment Share on other sites More sharing options...
boonman Posted November 12, 2003 Report Share Posted November 12, 2003 I wired a toggle directly from the stator. I came off the yellow wire from the stator, (I have a ricky stator) and went to a switch, and then to the lights. it's not too compicated. I wouldn't even use any of the stock light wiring. I did the same thing with the kill switch. I eliminated it. And I cut all the light stuff from the harness. Quote Link to comment Share on other sites More sharing options...
