paddyheff Posted March 15, 2014 Report Share Posted March 15, 2014 I was changing the rear brake pads on my banshee and it was all going well until i went to put the caliper back on. The piece of the caliper which holds it to the quad the piece you bolt on through is sticking out to much and will not allow the brake pads back far enough for them to go down over the rotor. Is there a way of moving this back ? Quote Link to comment Share on other sites More sharing options...
Surfrjag Posted March 15, 2014 Report Share Posted March 15, 2014 If it doesnt move over freely its stuck.try and free it up. If you can then consider a new one. edit. if you cant then consider a new one or rebuild Quote Link to comment Share on other sites More sharing options...
special06shee Posted March 15, 2014 Report Share Posted March 15, 2014 There is an allen bolt thingy,(Not sure proper name) but anyway it runs through rear caliper and bolts to mounting bracket. That must slide freely back and forth. Imo, your better off taking the whole thing apart and rebuild it. Chances are your gonna rip the rubbers trying to free it up if its really seized. Quote Link to comment Share on other sites More sharing options...
lil Doobie420 Posted March 15, 2014 Report Share Posted March 15, 2014 Soak the alen key in pb blaster first. Should break free. Like 06 said thos rubber peices are a bitch. Quote Link to comment Share on other sites More sharing options...
Zillaguy Posted March 15, 2014 Report Share Posted March 15, 2014 the caliper slides are seized... The caliper needs to be able to float on the pins... Your best bet is to buy the caliper rebuild kit, and rebuild it... Quote Link to comment Share on other sites More sharing options...
Banshee SE Posted March 15, 2014 Report Share Posted March 15, 2014 does the caliper has the emergency brake still? maybe you need to take some adjust. Quote Link to comment Share on other sites More sharing options...
ROAD RUNNER24 Posted April 11, 2014 Report Share Posted April 11, 2014 I just rebuilt mine. A lot easier than trying to get it broke free. Too rusty. Quote Link to comment Share on other sites More sharing options...
