bog before power
One side is cut away more then the other this is the airfilter side. Can also look at the syncing window. At around 3/4 throttle the small bebe on the piston (more of a small hole with an aluminum dowel pin in it) should appear in the window. If it never appears then they are reversed. Side with bebe goes to side with sync window on each carb.
if the sparkplug terminal(part that wire goes to) isnt tightened down or is striped and sitting in the cap it will rattle around when you place it on the sparkplug.
