bog before power
i got my shee all back togethor, carbs cleaned, no airleaks, 116 compression in both cylinders, 280 mains, 27.5 pilots, clip on the 4th up i believe. in 1st gear sometimes it wont hit powerband it will just bog and in other gears it wont hit powerband at all it will just sputter and run like crap anywere over 1/2 throttle. when i shut it off sometimes it will just pour gas out the carb so i guess the float is sticking, could this cause the problem?
Fix the float issue. It will basically dump fuel and flood , thus the bogging. You should notice it smoking quite a bit out of one pipe , that woukd be the side to check first. Also make sure you have the carbs on the correct side. You do not want to switch them.
  • Like 1
well it just runs like crap now, i moved the clip to 4th notch from bottom with the washer thing on top of the clip. it smokes alot! like blue 2 stroke smoke but alot, when i rev it up or try to ride it, before it hits the power band it sounds like it hits a rev limiter and it sounds like its "4 stroking" like its very very rich,it takes off like a jet once powerband hits though, it ran better when i had the needle on the 3rd notch, also the plugs are covered in gas, could it be they are fouling instantly from being so rich? or? my airscrew is 2 turns out by the way and i have 280 main jets
first off my needles have 6 slots? and yes up to lean and down to richen i just tried my air screw at 3 turns out and nothing happened, also just tried my needle at the 2nd notch from bottom and nothing happened, when i rev it up all the way and hold it, its like it just hits a rev limiter it sounds like crap, when im riding it will hit the band and just take off but it also hits the same "rev limiter" before the powerband.....
ok i just now tried running the needle on the leanest setting, still nothing, still acts like its hitting a rev limiter, it smokes alot when its hitting the "rev limiter" i know theres not really a rev limiter but it sounds like it when i rev it full throttle, heres a video of revving to full throttle, also my tors is disconnected correctly View My Video
parking brake switch on clutch perch completely disconnected electrically? green/yellow wire from cdi not grounding anywhere? that is the only rev limiter..
