steering issues?
gordo
92 banshee with +2 arms and stock steering stem. I turn the bars all the way to the left or right until stem hits the steering stop. my wheels have almost an extra half inch of play inwards which causes a lock up and if you go fast enough your going over the bars! ive checked for alignment issues, tie rod tweeks and have no idea on why it would do this? also running spacers on 1" spacers on hubs? thanks any help is greatly appreciated.
I've seen more the stop on the frame bent/worn. A spot of weld on each side and dress it down til it stops before the wheels cam over.
Same solution I had to do for mine. Bent the steering stop on the frame up which was allowing the wheels to turn past full lock and sending me over the handlebars a couple times before i could make it back to camp. Might loose the spacers as well which could be causing strains on the steering system.
