First fire since last season
And my trans fluid just pours out the clutch cover breather where the water pump is. Within 30!seconds of firining. I took out the dip stick to see if it was pressure related but that didn't help.
I have another cover with the block off so I may just stick a bolt in the hole and call it done.
But has anyone had this happen?
It's traveling up and coming out at a point higher than the motor? The Tranny should not be pressurized on start-up. If your getting compression into the tranny area…you have a seal that's gone bad somewhere.  :unsure:
