mxdinosaur Posted March 9, 2014 Report Share Posted March 9, 2014 I just went riding and hit a whoop really hard. The bike then started to bog on the right cylinder everytime I hit some bumps after that. It will pull clean on flat ground, but when I hit some whoops, the right cylinder wants to cut out. I run stock carbs with a twist throttle. I have never had this problem before. I checked the plug wires, and they were snapped on. Any ideas? Quote Link to comment Share on other sites More sharing options...
Pasi S. Posted March 9, 2014 Report Share Posted March 9, 2014 Check intake boots. I had a small cut and it did the same. Quote Link to comment Share on other sites More sharing options...
foxrider603 Posted March 9, 2014 Report Share Posted March 9, 2014 Bad ground maybe Quote Link to comment Share on other sites More sharing options...
sstaton1983 Posted March 10, 2014 Report Share Posted March 10, 2014 Check your float level. Quote Link to comment Share on other sites More sharing options...
Methfireroad Posted March 10, 2014 Report Share Posted March 10, 2014 X2 ^^^ Quote Link to comment Share on other sites More sharing options...
booxzzy Posted March 10, 2014 Report Share Posted March 10, 2014 do detailed check from ground up Quote Link to comment Share on other sites More sharing options...
mxdinosaur Posted March 10, 2014 Author Report Share Posted March 10, 2014 definately gonna check intake boots, running a toomey air filter setup. May have cracked an intake. what level should the floats be at? Quote Link to comment Share on other sites More sharing options...
uman1030 Posted March 10, 2014 Report Share Posted March 10, 2014 what level should the floats be at? 20mm-22mm Quote Link to comment Share on other sites More sharing options...
Jasonc Posted March 16, 2014 Report Share Posted March 16, 2014 Check for the brass washer under the main jet that hold the " emulsion?" Tube in place, with out them the tube can slide up into the carb throat and cause a bog Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
