38mm mikuni tm on banshee
Man , you are changing stuff that does not effect bottom end trying to cure a bottomend problem.
When the bike is warmed up and idling and you crack the throttle open to try to rev the bike up what does it do?
If it dies or stalls it is probably lean on pilot or needle down low
If it smokes quite a bit but goes ahead and boggs a bit but cleans up and then revs nice then it could be rich down low. (Pilot or needle)
Are you running a single 38mm or two? If you have two then tuning will be a little more difficult on a lightly modified bike.
You can probably swap em for some 33-35mm carbs. If you wana try them again crank the timing up to like 7 and it will make it much easier to tune those carbs. If it doesnt have much added compression over stock it will be much easier to tune with timing.
