what supsension to get?
2005shee
ok im looking at suspension set ups to get ive got a little bit of saving to do still but I would like to know how much ill need. I live in southeast ky, all I ride is wooded trails kinda fast but not extremely hard on my quad, I ride all year round so temps will range from 20-100. I was looking at a set they had of elka stage 1s and full flight st + a arms for 850 but only front shocks, same full flights with elkas stage 2s for 1150 just front, a set of stage 3 elkas with back included for around 1300 plus 350 for a arms, and fox float fronts only for 695 and id get +2 a arms for around 350. question is are the elka 2s or 3s worth the extra price? how would the foxs compare in my conditions? is there some other brand I should be looking at? if I get a set without the back what should I do, leave it stock, match it or is there a certain back shock that would be better? like I said before wooded trails is where I ride im also planning on getting an anti vibe steering stem and fast flexx bars and a steering stabilizer, I want a smooth ride I don't do big jumps at all, but theres a lot of drops and whoops that I have to ride here in the mountains. also would long travel make much of a difference?
ATV galaxy you can get a full set of custom made elkas stage 3 front and rear for $1255.50. They are 1395 but once you add them to the cart you'll get a 10% discount wich will show the real price then.
While i like the way they look and i Have a set sitting here still brand new uninstalled. I haven't actually ridden with them so i cant give you an honest answer. They look great tho! and appear to be a quality product.,we'll see.
Fronts - Go with ELKA Stage 3's or don't even bother. You wanna get the ones you can adjust compression on at the least, otherwise just go with a WORKS shock.
Rear - You can stick with the factory shock or get the factory rear re-valved and freshened up and it will be fine. If you have the cash, Getting the Rear ELKA will be nice, but it's a luxury you might not need for your riding.
+2+1 A-Arms with ELKAS FTMFW!   :clap: DO IT!!!  :headbang:
Any top company with YOUR set up will get you considerable gains. Like, new bike feeling gains. You'll be riding faster everywhere. I went from stockers to works triple rates. I loved it. I blew the shocks up, still 10000x better then stock. Now I have fox, I really like them too
well im pretty sure im going with the stage 3 set and even if I don't have the cash theres a set on ebay for 1300 and they are brand new and you still get the custom set up and all. an I was planning on getting either the full flight +2/+1 or the alba +2/+1 long travel a arms and ill probably go with the lt considering there only 398 so like $50 more. all together should be less then 1700. would this be a setup you guys would recommend? and you guys wouldn't recommend the flexx bars for the price? theres a lonestar +1 anti vibe steering stem and fast flexx bar combo for 600. and what brand steering stabilizer works good with the shees?
and what are the advantages of going with the round swingarm?
WAAAAAY easier to make adjustments. Allows for more adjustment when it come to chains and gearing choices. TONS lighter!
I love the idea of the steering stabilizer. I run them on everything. A stick style will work out fine for you. (They are all basically the same…..Moose has a low price) Instead of Fast Flex bars…..Go with a +1 or +2 anti-vibe stem (I like the +2 but I'm 6' tall) Then look at the Precision Handlebar Suspension. It's cheaper than flex bars and works WAY better. You don't see a lot of Banshee guys run them…..But I bought an 09' YFZ450R and it had them on it. Can't believe how much of a difference it makes on the abuse your wrists/body gets from the bars. One good tree root in your trail and a decent speed and you'll know why a bar suspension and steering stabilizer are priceless!
thanks for all the opinions guys, ill definitely look it the swingarm too, should I stick with stock or go -/+. windcityjohn400 would you care to post a link to that precision handlebar suspension? I couldnt find it. and should I get an extended axle while im at it?
thanks I heard the -1s were supposed to handle better for the tighter stuff so I was thinking about it. any downsides? and I doubt ill ever be taking this thing to the dunes closest ones are about 9 hours.
ya that's what I was asking, I kinda of figured it would come up easier but ill probably go that route if/when I get a new swingarm but that might come later still but ill definitely be looking into one.
when alls said and done how close would it be in handleing to say a yfz? just kind of curios because ive got a few friends with some and they always dry to dog on me for having such a bad handleing quad, not that its really that bad but they seem to thing theres is the best thing ever even though ill whoop on them in a drag.
here you go >>>>>>>  http://www.precision-rp.com
