Start then no start
ignert
I picked up a banshee really cheap and all it needed was a stator. I put a new stator and adjustable timing plate and tors eliminator in and set it to +4deg. Started first kick, took it around the yard yesterday to warm it up to adjust the idle, shut it off for a minute and now won't start. Tried it again today and the same thing happened. Any ideas? Please help!
Haven't touched the carbs other than doing the tors eliminate kit on it. The last owner said it had 160 jets. Sound right? Idk, I'm new to this
NO!!!!! With just fatty's you should be around 260 and probably 27.5 on pilots. This is around sea level.
Its possible, sometimes its just easier to find out what is not the problem to cut down variables to actually diagnose what is the problem. Lot of things on these can have similar symptoms for totally different causes. can be frustrating when you don't know where to start. Jetting, airleaks or electrical problems are almost always the cause of most any issue with these. Alot of times there is no quick fix with out some testing.
Its possible, sometimes its just easier to find out what is not the problem to cut down variables to actually diagnose what is the problem. Lot of things on these can have similar symptoms for totally different causes. can be frustrating when you don't know where to start. Jetting, airleaks orelectrical problems are almost always the cause of most any issue with these. Alot of times there is no quick fix with out some testing.
True dat
