Just placed an order through alloy boltz for their stainless steel polished banshee kit and foot peg bolts, that was every bolt nut and washer except for the lower shock linkage bolt with the grease fitting, Upper A-Arm, Fine Thread Lower Motor Mount, and Main Swing Arm Pivot Bolts. Their customer service was great and they shipped out the kit with in 24 hours once it gets in ill update this and let you know the quality of the bolts and finish. This kit cost me 140 dollars shipped.
I have the same full bolt set... Along with the peg bolts and the lower motor mount bolts... The fit is awesome, and every bolt, nut, washer is polished like jewelry... I did not use the cylinder base nuts or the head nuts, or the rear sprocket nuts... I bought chrome acorn nuts for the them from my local hardware store.... I like the look of the acorn nuts more for those spots..
  • Like 1
Best thing ever. I've had two kits, have tons of left-overs that I've used for a wide variety of things..
USE ANTI-SIEZE
^^^THIS^^^ anti-seize every bolt or you risk a chance of the threads galling and breaking the bolts off.... And, dr+illing out stainless is near impossible..
^^^^^^EVERY BOLT!!!! ^^^^^^^
E-V-E-R-Y-B-O-L-T
Even the little ones for mounting your plastics.
(Also don't freak if you don't use them all.)
You'll find a few that you decide to stick with the stock bolts.
